Hi, still in a predicament on my exterior summerhouse insulation.
Initially bought Celotex 30mm but was told the foil acting as a vapour barrier could cause mould underneath.
Walls are currently (from inside to outside): Plasterboard > Foil bubble wrap VCL > rockwool + 4x2s studwork > 2x 12mm OSB staggered > breather membrane.
Now I want to add exterior insulation before cladding.
I guess more Rockwool (50mm acoustic) is the right choice cos it allows breathability... but I need to screw some framework to the exterior before adding rockwool, otherwise the cladding will have nothing to screw onto.
Is there some type of metal framework I can use? Like I-beam shaped so I can tuck the Rockwool into it?
Also would the Rockwool attract any moisture seeping in through the cladding? I know they say moisture resistant but mine got wet in the rain and absorbed it like a sponge.
Cheers.
Cheers.
