- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
A bit confused by the problems re the fitting of an exterior bulkhead light. It is this model – a basic polycarbonate item replacing an old Appleby metal version which appears to have stop working recently (maybe through corrosion?) Anyway it has been quite difficult to fit as it the system of six security lamps are connected by armoured cable. Eventually having got the lamp secured and connected it failed to work thought the rest of the circuit works fine. I put the multi-meter on the terminals and the 500v ~ reading switched from 19v to 80v and then back again. On the 200 v ~ it shows a constant 71v. This is all a bit perplexing but I wonder if there is some likelihood of damp having penetrated the armoured cable. Does this sound possible?
Any thoughts much appreciated.
