Exterior Painting
28 Jun 2004
I've cement rendered the outside of my house but the weather isn't too good now so I'm thinking of leaving the painting till next summer. Can I leave it exposed as it is or do I need to take some precautions?
I've noticed a few (hairline) cracks in the cement render, should I fill these in now or is it best to leave it till next summer when I come to paint it and fill it in then? If the latter will I need to use some fungicide?
any hairline cracks are normal from the drying out process. Its really up to you, but any moisture entry will be minimal. i would be inclined to leave it till a dry spell in the spring. dont get to hung up on the waterproof side of things, you have an outer skin of brickwork and a cavity to deal with the water penetration. You just want a dry period so that any moisture in the wall is able to get out before its painted
Thermo
