Is it pebbledash, roughcast or spar?
Either way, all you need to paint it is masonry paint, a good quality masonry roller and brush. If it has already been painted, the hardest job has been done. If not, prepare yourself for tedium and an aching arm, especially if it's spar.
If it is extremely exposed to bad weather, you will need to use a good quality masonry paint such as Johnstone's Stormshield, otherwise, most quality brand masonry paints will be fine - Sandtex, Weathershield, etc. You may choose a pliolite masonry paint rather than water/acrylic, which should last longer and stay somewhat cleaner - Johnstone's Stormshield Pliolite would be my pick.
The most important part is the preparation. Exposed areas tend to get dirty or covered in green mould/algae/lichen so you may need to clean the walls first. Use a fungicidal wash or diluted bleach solution to kill any mould/fungi spores if necessary and rinse well. For dirt only, use soapy water and again rinse well. Allow all surfaces to fully dry before painting.
If you have unpainted spar, you will find that you will get a lot of the chips falling off as you wash it/apply paint, so brush it all with a stiff nylon bristled sweeping brush before painting. Avoid wire brushes as particles of the wire can get stuck on the wall surface and will begin to rust, leaving you with rust spots bleeding through the finished paint job.
If the 'dashing is unpainted, you will need to dilute your first coat to help ease application - follow manufacturer's instructions but I'd recommend diluting slightly more than they suggest as a first coat on bare 'dash. You will find out which application method is best once you start - sometimes even the best thick pile masonry roller sleeve won't get into all the nooks and crannies, so you will have to use a combination of roller and brush to get the best overall coverage.
