So the problem of the brown and yellow stains coming through masonry paint was solved when the exterior painting was done again by the same painter, ie he was given a chance to put it right - in April.
He just painted over the first attempt. I believe water-based paint was used first time round and then oil-based to rectify the staining problem.
However, a small area of the masonry paint is suddenly showing blistering. It's on the prevailing wind side and the past month has been gales and slashing rain. If you press a blister it shows paint underneath, not bare wall.
Before the blistering was evident, the matching area of the interior hall wall showed "salting" and a damp meter test proved positive (the walls are cavity filled).
At the very start of the job the exterior wall was scraped down and some cracks filled in but it was not re-rendered (my decision). I know that the first paint job was not properly prepared because I sent off some samples to the manufacturer. Could this have happened again?
But having got A N Other in, he says that a large part of the exterior wall should be re-rendered (gulp) and then repainted. £1000
Do I have to bite the bullet on this or could there be another solution? Are the blistering and internal damp necessarily related?
Thanks in advance.
Thanks in advance.
