exterior stair case
20 May 2009
London
Hi
Im quoting for an exterior staircase at the moment, only ever made interior ones from hemlock up until now.
Any thoughts/advise on species of timber, finishing and anything else I should bear in mind?
Many Thanks
Have you been asked to price for a full timber staircase?
Does your client have any drawings or a design in mind?
Is it just a few steps or is it a conventional stair going up a few landing levels? More info required.
I'd imagine an all wooden external stair would be a very high maintenance item. What about a steel stair clad in wood to give the appearance of a timber stair then if through time if there was any deteriation in the timber it could be easily replaced. Wet wood as you probably know is very slippy so the treads at least would need a non slip surfacing applied to them.
HTH
Alan
hi
Thanks for your reply
the stair case is to a listed building so i believe an exact replica needs to be made.
the stairs are a very simple staight flight of 13 steps to the first floor with a small landing at the top and long posts down to the floor.
If it's for a listed building the conservation officer may well have a preference for the type of wood if not using exactly what its replacing anyway.
I would recomend a hardwood (or VAC-VAC pressure treated softwood) open riser staircase. Also look out for 'non slip' inserts for the treads as they can be very slippy when wet.
alex
