Hi
We have a west-facing bathroom wall which we have taken back to brick. We're confused about the best way to insulate the wall and reduce the risk of damp from the inside (or outside!).
The current plan is to build a stud wall (studs at 300mm intervals), fit Celotex in between the studs (pushed back and attached to the brick to leave an air gap) and then board out using 12.5 mm Marmox - taped joints and tiled from floor to ceiling.
Not sure if this is the best approach? Would I be better using a rockwool type insulation? Do I need to use a vapour barrier? I've been advised not to dot and dab Marmox boards in this case, but would this be an option?
The wall is double brick with a cavity.
Any advice will be gratefully received!
javascript:emoticon('')
