external bell wont sound on accenta g3 alarm
20 Nov 2011
Tyne and Wear
hi all i have a problem with my accenta mini g3 alarm. i bought a house and when it came to sorting the alarm out without knowing what i was doing the alarm went off but i had no reset code. the only way i could silence it was to pull the main fuse out. now ive got to the point where everything seems to be working appart from external bell. the control panel says everything is fine and when i do the tests the outside strobe works but not the bell. any help wud be much appreciated
Check too see if the siren trigger has been knocked out. Its terminal B at the siren terminals. Try touching the A terminal with the siren trigger wire to test the siren, it should activate when these to wires are in the A terminal.
Oh and be careful around the 240v live in the pannel.
Shout if you need me :D
