Hi everyone. I need to replace existing external box that has been damaged with a new one. System is accenta g3. I'm thinking of replacing with a Honeywell ag6/wb active guard. Are they compatible please. If so which wire would go where?
Yes and depends on how it is wired...take picture of old connections in old bell box before you remove it...
Ok then you will have to open up panel and post picture of bell connections inside, this will be on the bottom right of the pcb there will be strobe + and - bell + and - and T and A ...
Wire to new box as follows
R- blue
Sw - black
V+ red
V - yellow
Strobe - white
Ok
