- Joined
- 9 Sep 2009
- Messages
- 10
- Reaction score
- 0
- Country
Hi all
I am about to decorate the outside of my house but on the newer extension (less than 10 yrs old) the builders used a beading on the edges which are now rusting, a couple of places quite badly. (I forget if the beads are galvanised or stainless steel, whichever they are the ones used for the windows are fine).
Anyway, I've had various advice covering everything from cutting out the beading, replacing for the non-rusting beading, others have said that it can just be sanded down and painted over (but will rust through again in time) or thirdly it could be sanded down, sealed with varying kinds of sealant (one guy mentioned using marine grade stuff as I'm 1/4 mile from the coast) and then after that painted, which should last 5+ years.
I wouldn't attempt the bead removal myself and I've been quoted £750 to do this but would rather avoid having this done if it isn't needed. Another guy quoted me £75 to sand it down (scaffold tower needed) and seal with marine grade sealant and prime ready for painting for £150 (more like it).
Tackling the latter option myself is also out of the question due to back problems.
Any advice would be most appreciated.
Pete
Pete
