I am in the process of doing a loft conversion and have a question about the outside finish to one of the sides of the dormer.
It's a stud wall approx 3.2m long and 2.2m to 0m high. Because my dormer will be built right next to my next door neighbour's dormer the space between them will be very tight. Not sure how tight as of now but I am guessing the spacing will be around 250mm.
The front and opposite walls will be finished with tiles and in order to minimise maintenance and to make the building process easier I am looking for some suggestions on the finish of that specific wall.
I don't really care about appearance because I will not see it, it will be hidden... so... as long as it's quick to install, relatively cheap and durable it should be fine.
Someone suggested lead flashing, but I suspect it will be very heavy and costly. Has any of you guys come across something like that?
Thanks!
Thanks!
