External Floor Tiling
8 Dec 2014
West Midlands
Hi all,
I have just had in excess of 70m2 of tiling done as part of my renovation project, and it has been quite painful. There is one outstanding issue which is the floor tiling of a storm porch. As the porch is open to the front and the side the floor gets wet and I had expected it to drain to the entrance. It didn't, in fact the water accumulated by the front door. After much discussion with the tiler, I brought more tiles and he had another crack at it. The discussion included him blaming the builder for not putting a fall on the concrete base. During this discussion I said to him that my research was there should be at least a 1:40 fall on it and that as the finishing trade I made it clear that he was responsible.
After the refit Its no better and its obvious there is not enough fall. See link to video of https://drive.google.com/folderview?id=0B5QDEFAvLazZUDZsSF9mUld4UGc&usp=sharing. I have said I will get someone else into do it, take the cost of his bill and pay him the remainder. He is not happy about this, but I don't see what other options there are. Am I being unfair?
I think the base should have been built with a fall, and I don't think you can blame the tiler. At the very least, the problem should have been realised at the outset, and a solution discussed. You can't blame the tiler for tiling what was there.
Cheers
Richard
The base could have been built with a fall but a professional tiler could have easily overcome that lack, and tiled to a fall with a slight nosing (which also seems to be missing).
The key point is that you gave clear instructions for what was required, and if the tiler agreed to tile to a regulation fall then the tiler is at fault.
FWIW: all exterior and wet room/area tiling is tiled to falls by default - exactly as all drainage pipework is fixed to falls.
