Hi all, I've referred to this excellent forum on many occasions and so far, have always found the answers to my questions through the search facility but I'm struggling a bit this time!
I have a garage next to my flat which had a power supply fitted to it over 15 years ago. The electrician used what I believe is some sort of fire resistant cable - orange sheathed copper with two internal copper stands set in a chalky/ceramic type substance. This runs from a second consumer unit in my first floor flat and spans the gap between flat & garage (5 1/2 ft) sitting inside a galvanised steel channel bolted to both structures at a height of about 9ft above the ground.
This weekend, the power to the garage has started tripping out constantly, I suspect the cable has degraded somewhere allowing water ingress as it does this with the c/u in the garage completely switched off. The garage side was completely rewired a couple of years ago.
Anyway, my question(s) is this - am I required to use SWA for the short run outside between the buildings with the above set up or would twin & earth be okay in a suitable conduit (what?)
If I do have to use SWA, can I joint this to twin & earth as soon as it enters both buildings as it has to run around a few corners and that ain't gonna happen with the SWA!
I have had a look using the search but most outside installations seem to be sheds & garages a good few meters away from the house and at much lower heights than mine. I should also mention, I'm in Central Scotland.
Any advice greatly appreciated
Regards, Jim
Regards, Jim
