Hello All.
I hope someone can help clarify a concern I have.
My daughter has recently moved into a new home , and is wanting to replace the existing electric cooker with a range with a gas hob.
As the existing cooker has no gas supply , she has had a quote for this and other works , that states the gas supply for the range will be ran externally along the wall and back into the kitchen at the range .
The external wall is facing a neighbours property and is between my daughters house and the neighbours (Not on the neighbours buildings).
Is this allowed ? , and if so should the pipe be protected?, I know with electric cables the cable is sheathed/armoured usually.
Thanks in advance for all help given
Glenn
Glenn
