Greetings,
My mother had the outside of her house painted about 6 years ago, masonrey paint on the walls and weathersheild gloss on the sills and pipework. Recently the gloss started to flake a little so I rubbed down with fine wire wool, touched up and bare sections with external primer. When dry cleaned everything up with spirit. I had to leave before I started to paint and return a few days later.
The paint I bought is weathersheild black gloss.
When the paint is applied after about 15 mins it begins to recide leaving behind spots without paint, acting almost like painting oiled based paint on a wet surface. It did this on sections primed and not primed so is not the primer, and on pipes and the sill so it not due to the surface.
I did however find out after painting that it rained for a few mins the night before I painted, the surface at the time was very much dry. Is it possible that there was some crud in the rain and it left deposits that caused this ?
Would a light rub down with a fine sand block then wipe over with white spirit and then paint right away would fix this ?
I would ask if it was the paint but some large sections are perfect, and yes the brush is a harris gloss brush and brand new out the pack at the time of painting.
I have painted using the same paint on the same materials painted here and never had this problem before.
Piccy ( paint work looks rough I know as I stopped when I realised what was happening )
Thank you in advance for your time and words of wisdom
Regards
A
Regards
A
