External hard drives
4 Jun 2009
London
What does passport mean in respect of external drives? Am looking to buy one to backup pics/music etc and mate says oh but that isn't a passport one
Which one, make and model, are you 'looking at'?
Is it a USB connection?
Almost every external harddrive, if they are USB connected will work on any PC and laptop.
Suggest you look at some with their own external power supply.
Regarding your mate and his comment about passport, ask him what he is talking about. Possibley illegal immigrant harddrives if they haven't got a passport. :LOL:
I thought “My Passport” was simply the brand name "Western Digital" have given their latest USB hard drive products; presumably this means the drive your looking at is an older model.
Ive got a USB 500GB WD, works OK as external back up but it's a bit slow.
Could he mean something about Microsoft Passport? But I thought that was only to do with making it easy to sign in to Microsoft sites using the same ID/password.................. Unless he's thinking about File transfer or something?
I've got a Maxtor (now Seagate) 320gig hard drive (which is nearly full - what on earth have I got on it!!) and I have to say, I can't fault it (yep, it'll break tonight). Just plug it in and away it goes. My brother's got one too and his power pack died a death last week. Phoned Seagate and they sent out a new one free of charge. Bonus.
Everybody has their favourite makers. I recommend Western Digital or Seagate. I would say stay away from Maxtor drives. Not sure if the reliability has improved since Seagate took over.
Don’t 100% rely on an external hard drive since it has a more higher chance of failure than an internal one. Always have another backup on a different storage medium. E.g dvd-r’s.
djrock
Passport is the 2.5" Western Digital drive. When choosing a drive this is what you need to consider... There are two sizes and 3 different types of connection:
2.5" Drive
These are the same drives as used in laptops, at the moment they go up to about 500gb in storage and generally spin slightly slower than desktop drives. Because of the small size and slower spin they use less electricity and generate less heat, this allows them to be powered purely by the computer via the USB lead. So these are ideal for carrying with a laptop or for frequent chopping and changing. Performance is generally slower than 3.5" drives.
3.5" Drive
These are the same drives used in desktop computers, they can go up to about 1.5tb (1500gb) and often run at the higher spin speed of 7200rpm. They generate more noise, heat and always require a separate power supply to power them. More often used for backup devices due to their larger capacity.
Connection Types:
USB - Most common connection and can be found on all computers now (for the last 7 years or so). This currently runs at around 400mb per second on newer machines (5 years or older you may only get 200mb) This is normally find for backups and day to day use. Only requires a power plug for larger drives.
Firewire - Commonly found on Mac's but also present on some laptops and PC's, especially used for video editing. Can run at either 400 or 800 mbps (depending on plug) and does not rely on the computer processor so is generally quicker than USB. Downside is that not many machines have it, not usually used unless you really need that boost in speed. Almost always requires a separate power plug.
eSATA - New interface just starting to appear in PC's and some laptops. This is an external version of the connector found inside most PC's to connect disks and as such is much faster than either firewire or USB. The cable is usually stiff and unweildy compared to USB / Firewire. Usually has a price premium and unless you have a specific need to have the extra speed is probably not worth consideing at the moment. Always requires a power plug.
Hi guys, thanks for all the comments, I have bought one online from Dixons, it's Western Digital 2.5" PASB 250GB and cost £45
Knew all about connections (USB etc) just wasn't sure what difference was between one that was passport and one that wasn't
Cheers again
