I have a 20A RCBO from my house CU feeding my garden studio via a 2.5mm SWA into another CU in my studio fitted with a 30mA RCD and MCBs.
I would like to have an external FCU on the outside of my studio to which I can wire a Solar inverter (via AC isolator).
As the inverter needs it's own circuit, and I do NOT want to drill through the studio wall to the CU due to various issues with its internal insulation, can a qualified electrician take a feed from the Wylex box already on the outside of the studio (where it's wired to the existing CU) and fit a new IP65 CU like this fitted with a suitable MCB and then onwards to an IP65 FCU ?
Once that new circuit is in then I can wire up my inverter to it.
Diagram with existing setup attached.
Thanks!
Thanks!
