Bought a new external light fitting to replace an old existing one. The problem is the colour of the wires and fitment to the old unit doesn't make any sense in relation to the new fitting. From the house feed there are two sets of cable coming out. The red wires were twisted together, the two earths twisted together also, and two black wires connected into the old choc block into two seperate terminals. The appears to be a switch for the light fitting inside the back door. With out the use of a volt meter is there anyway to work out which wires need to go into the new fitting which has the following connections Blue/Brown/Earth/L1
Hope you can help
Shakey
Hope you can help
Shakey
