External Lights
GTL
18 Oct 2005
Berwickshire
I want to fit three Halogen 150w lamps. One to the left and right. One central with pir. All three lamps should come on when the pir is activated. There is at pressent two Halogen lamps, one 500w the other 150w activated by switch. Neither light has a pir. Your thoughts would be appreciated.
some lights with PIRs have an output to wire other lights into. just run cables between the lights
Voltek do a very configurable system.
Control unit will switch up to 2500W.
Control centre will give one shot or constant and will bleep if someone enters the beam during daylight (this feature can be muted), this is very useful for protecting/alerting sole occupants during the day.
