Hi, Can anyone point me in the right direction as to whether the following will work ?
I want to power:-
6x 240v 11w lights
1x 20w transformer (for a set of 'step' led's)
1x v small pond pump (450L/Hr)
These will be powered from an RCD on a 13amp socket indoors
My Plan:-
I've seen a 3 gang outdoor socket with 10m of rubber outdoor cable, i was planning to use this to get power from the RCD socket indoors to the underneath of my decking (dry, secure location), then distribute (plug in) the 3 supplies above using 0.75mm rubber outdoor cable to each. Will it be ok to wire the lights like this on one spur running into each lamp before finishing at the last one about 8m away ?
Any advice would be greatly appreciated !
I want to power:-
6x 240v 11w lights
My Plan:-
