Hi everyone.
Odd ball question, I would be interested in sensible input as to the following problem, not my property!
The cavity wall was retro-filled with the Dreaded Cavity Wall insulation, on this property the Cavity Wall Insulation failed, damp patches have developed in the usual form, here and there.
This post is NOT about the pros and Cons of Cavity Wall insulation [everyone has an opinion about that] Also the post is not about the damage that can ensue internally, damp walls peeling paper loss of heat Etc. Etc. Etc.
This post is aimed at, the External Roughcast render? The internal Plaster and décor finishes affected will be addressed, but the external roughcast render [looks like a so called “Wet Dash?”] is the area I am interested in any information at all about.
Externally, the roughcast render has had multiple coats of presumably various types and Quality of external masonry paint applied, in dozens of areas of this external wall at all levels, the applied paint finish is De-bonding or bubbling away from the top external surface of the Roughcast Render. If these areas are touched, the paint film is noticeably hollow, having totally De-bonded from the surface of the roughcast render, the paint film even crackles.
Now for my Question, sorry it has taken this long to cut to the chase?
Has anyone undertaken Cavity Wall insulation removal? And tried to re-decorate the external surface of the affected walls, if so what was the result? I am seriously concerned that, the paint is being De-Bonded and forced off the external surface of the Roughcast Render by the Soluble Salts emanating from the Mortar and bricks on the outer leaf of the affected walls, all four walls of a detached two story property are affected. I am considering that the removal of the Roughcast Render, never mind just the blown external paint finishes is a potential requirement, because the application of new paint to Roughcast Render that is Saturated with Soluble Salt [at all heights, not just the ubiquitous 1.0m above DPC] will seriously affect any new external paint finish that is applied?
I am considering the removal of the damaged EXTERNAL PAINT by Scaffold and Soda Blasting.
I am struggling to find anything meaningful on Google? .
Thanks for reading, are you still awake?
Ken.
Ken.
