External oil boiler flue distance to gutters
13 Feb 2005
Hi
I'm currently planning ahead some building work which will involve re-positioning a wall hung external Grant oil boiler.
Its new position will depend on the allowed distance of the flue from the gutters.
In the manual it states the flue has to be 600mm. It also states that this can be reduced to 75mm with protection.
Can anyone tell me what form of protection this means?
I'd like to have some idea of what I want before getting anyone in for quotes and advice.
Many thanks
Its called a heat protection shield.
Which should be installed to the underside of the gutter.
They are usually 1000mm long with an air gap to the gutter of 5mm.
Always check the manufacturers instructions.
Andy.:cool:
Protection is usually by means of a metal deflector plate fitted under the gutter. Usually not very nice to look at!
Typically 1000 long and perhaps 50 wider than the gutter.
The exact dimensions will usually be given by the manufacturer on request. Sometimes the installer is expected to decide!
Tony
Thanks for that info.
Is this something that's bought off the shelf or can it be constructed with sheet metal?
Best to use Alumminium as this won't rust I have used a Gas fire Closure plate folded to suit the profile of the soffitt & gutter, (the flue gas temperature from your Grant boiler will be 60 - 80*c so not overly hot!! ;)
