external pir
18 Mar 2005
has anyone installed / can rec. an external pir to activate an intruder alarm system, i have used pyronix beam detectors before but would prefer a single detector if available, cheers
Not recommended! Animals, birds, spiders... could all set the thing off. The last thing you want is an intruder alarm that false alarms. Everyone will ignore it and you neighbours will get p155ed off! :evil:
You'd be a lot better off with Pulnix/Takex beams.
Is the problem with a beam getting power to the far end ?.
If it is then with careful layout you can have both units at one end and a passive reflector at the far end. It is best if the sender and receiver are screened from each other to prevent stray from the sender reaching the receiver.
82, get with it.
Fireman22,m as you seem to like Pyronix, their XD10T TAM should suit your needs, it's made for the job.
Not cheap, but it DOES work very well.
Bernard, it's possible to still buy units that work in that way.
Europlex, I have used that type over very short ranges ( conveyor belts etc ) but over a long range the lower cost ( simple ones ) can get confused by reflections from an intruder close to the sensor being the same as that from the distant reflector.
The ones that measure the distance to the reflecting object are almost perfect but unfortunately (much) more expensive.
Europlex cheers that external det looks perfect, do you know how expensive they are tho? just roughly, cheers
