External Power For Chistmas Lights
8 Oct 2006
Hi all
I was thinking of buying one of these key opeated MK external power pkugs for the christmas lights - nothing big just one light really
https://www.amazon.co.uk/Masterseal...qid=1506428373&sr=8-1&keywords=masterseal+key
I have power sockets directly opposite on the internal wall (not spurred in any way) so I was hoping to take the backing plate off one of the sockets inside the house and drill directly to the outside and into the back of one of these. The only run of cable is from the inside house socket through the wall to the inside of the new socket outside - so hardly anything
So would using using 2.5mm T&E cable be the way to go?? The cable wont be visible anywhere
The house is protected by an RCD also
I know its notifiable but just wanted to see what people think - may just put cable out of the window for christmas instead!
Do you actually need key operated switch? A double outside socket with normal switches is much cheaper.
Apart from that it is OK. Run silicon sealer round the socket case where it meets the wall so water won't run down the back.
It is in some parts of here:
I would mount a 20A DP switch beside the power sockets and drill through the back of the switch to outside. The DP switch means you can totally isolate the external elctrics in the event of a fault that trips the house RCD. It also saves the cost of a key switch, so you can use a standard socket in weatherproof enclosure.
Thanks all - yeh not sure if I do need the key operated part to be honest - its on a busy road but its not as if someone gonna rock up and plug in easily
We have three double sockets on the inside - the missus changed mind of where TV was going after we had electrics done so now those sockets are visible - I didnt want to put another visible switch next to them if I could help it as three doubles is a bot over the top as it is!
Saying that - I could just convert one of those doubles couldnt I???
Yes you could use grid switch components. You would need a 3 gang grid and cover plate, one 20A DP grid switch and two grid switch blanks
In practice as long as you seal the back box wall interface as I suggested it is unlikely you will get such a fault. I've had an outside socket for over 12 years now and never had the RCD trip.
