I have built some blockwork retaining walls around our new patio. The are about 3 foot tall. I plan on rendering them and installing a slate capping and slate patio.
I had planned laying the capping first which overhangs the wall and then rendering from the underside of this down to the foundation, then laying teh slabs up to the edge. Would this be ok? i appreciate that you wouldnt normally render to ground level as you would breach DPC's however this is only on a garden wall and not a house wall. Will the absorbtion of water from low level cause the render to weaken over time or make it go green etc?
If this is ok what mix should i use. Looking at previous posts they suggest 5 sharp sand, 1 cement and plasticiser. Should i add fibres or a waterproofer?
thanks
thanks
