External Render in Confined Space
5 Oct 2012
London
trying to think of the best way to external render a side wall to our extension. at the moment it will be built in 215mm block with no cavity, and the extension come upto the boundary line of our property. Our neighbour has a conservatory which is about 25-30 away from the boundary line, which makes access to render that way very hard. i was thinking as the wall was being built up it could be rendered in sections from our side. or i could render wbp ply sheets and then just drill it into the wall???
any other ideas anyone?
hamazz
i thought of that, but it is out of the question, as there is probably going to be an external insulation/render to match the rest of the house, i was thinking of applying it to a sheet of ply or so, and then just the need to tie it into the blockwork
hamazz
