hi,
I am planning on rendering an extension wall but I first have to scrape off the old stuff, which should not be a problem as it’s quite dry and flakes off just by rubbing it with your hand. I plan on mixing my own plastering sand and cement. I have 2 questions:
1. When I scrape down to the brickwork, is there anything I should be treating the brickwork with before I render, bonding, waterproofing solution etc....
2. When I prepare my rendering mix, is there any other additives I should be adding before mixing?
Thanks in advance
Thanks in advance
