I would like to put an external socket outside under the carport but I'm not sure if it is allowed to tap off an internal circuit. It would be most convenient if I could just use the internal ring main, drill through the wall, and not have any cable showing outside. I would either extended the inner ring and or spur off via a switched FCU - Obviously the external socket would need to be a weatherproof type. As the inner circuit is protected by a 32 amp RCD would it be allowed and are there any restrictions regarding the postioning of an external socket?
