Hi about 2 weeks ago my cold water supply pressure dropped and i thought little of it due to the cold snap of weather, but then a few days later it dropped further, so much that my combi boiler would not come on when operating the hot tap. i went to the stopcock in the garden in the ground and using the stopcock key i fully closed the tap then fully opened it, then the pressure was ok good as new, this lasted for about 3 days then it dropped very low again, i wondered if it may be frozen up but there is water that sits around the tap and this was not and is not frozen so i assumed it the tap would not be frozen, but just to make sure i poured a kettle full of boiling water down there and left if for 10 mins but the pressure was still low. I then opereated the stop cock again, but this time i only turned it 180 deg and back again, i checked my water and the pressure was fully restored, this has happened about 10 times since sometimes twice a day and when ever it happens i just do a half turn of the stop cock and back again and it restores the pressure.
i am of the undersatanding the the supply to the stopcock from the street main is lead but the pipe into my house is copper. does any one have any ideas?
many thanks
many thanks
