I need to put up 4 External Sun Flood Lights 80watt each to a non-residential outbuilding.
I don't want to go down the road of fixing up a conduit or a metal trunking, nor do I want to use SWA (unless I have to!) , and would rather clip up a weather resistant cable externally to loop from one to the next, using suitable weatherproof glands. They will be fixed up 30ft from the ground.
Can anybody recommend a cable for doing this. Is arctic flex suitable - or is there a solid core alternative?
I will test it for safety, as I have gear to do so. And as its non-residential then I assume part p is uncalled for.
