Not sure if this is the right forum but here goes...
I need to install a telephone extension from my hallway (which has a master socket), to my lounge. For reasons that are best left outside of this forum I need to do this via the external, rather than the internal, walls.
I have a master socket that looks like this
Am I correct in think I can wire directly into this?
Also I understand that you need to use external cabling rather than the standard white extension leads. Would one of the following do the job?
http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Telephone_Cable_External/index.html
http://www.maplin.co.uk/Module.aspx?ModuleNo=66&doy=11m10&C=SEO&U=strat15
Tenth one down - http://www.phonesockets.co.uk/shopping.php
Obviously I will need some external cable clips, and a slave socket at the other end.
So presumably the following would provide all that I need?
Third one down - http://www.phonesockets.co.uk/shopping.php
Are there any other things I should be aware of, or would need to complete the job?
Many Thanks in advance
