External wall light
23 Apr 2014
Leicester
I have just bought a new porch light to replace an existing old one. While removing the old one I have noticed that it has no earth, the new light has a metal case and needs an earth connection.
Running a 3 core cable in is not really an option but I was wondering if it is ok (safe/legal) to run a separate earth cable from the light fitting to an earthing point?
Any advice gratefully recieved
I can get to the cupboard containing the consumer unit fairly easily round the outside using trunking or the like.
If you don't mind trunking then just wire it properly from the CU.
Easier to do as Winston suggested, though.
If all conductors are wired to the CU, that may not be a convient place to have a switch to control the light.
An earth cable run on its own has to be a minimum size. 4mm I think,
1 Sounds like a bigger bodge. And the black wire may not goto the switch.
2 could be dangerous or not ideal for someone performing maintance on the switch and it being connected to two different circuits on a 2 gang
Thanks guys, I went with Winston's suggestion and got a new fitting rather than do a bodge job.
