Not necessarily, those joints can be cut along the elbow joint and remade - I have done this hundreds of times. Solvent weld I was told is the professional standard.so I was worried if any of those joints broke again … I’d have to replace it from inside .. it it is solvent weld .so I believe that’s good?
Look at fairly easy based on those photosJust asking how easy it is to push a pipe through based on that picture? Thanks
Well if the hole is already there (as in your case) then it’s a case of just removing any silicone/seal around the pipe, and once the old is removed, push the new one through. If there’s not a hole, then one needs to be put there, so a core drill.How do plumbers push pipes through the wall .. do you use a tool?
