I’ve got a 5m x 4m summerhouse that’s just one year old, it’s made from reasonably robust & pressure treated 20mm tongue & groove log boards & been painted with two coats of Cuprinol Garden Colour. It looks great & was fine throughout last summer but during the wet winter months & the heavy rain we’ve had, I can see that water has obviously been getting in between the tongue & groove log boards & making the inside damp & stained, mould has also formed on the ceiling & furniture. Not sure an internal membrane & dry lining will solve the problem as moisture could then sit in the cavity & may even make things worse.
I thought about over boarding the outside but that's going to be rather expensive so I’ve been looking around for a flexible, waterproof liquid membrane I could apply externally & then over paint. Being an ex-tiler, one product that springs to mind is “Aquaseal wateroroof tanking membrane” but has anyone ever used this externally on a timber shed before? Can it be over painted; do you think it would work? If not, does anyone know of a suitable product that would work?
