I want to fit a weatherproof (IP56/IP66) mains socket on an outside wall to enable ocassional mains power to be connected to a motorhome and/or external mains powered equipment.
I intend connecting it to a spare FSU mounted on the internal wall.
The existing FSU is supplied from the consumer unit, which has an RCD fitted.
The motorhome has a small consumer unit, which is also fitted with an RCD.
My question is: should the new external socket have its own RCD, or should it be a non-RCD type.
