I have just moved to a new house and it has a workshop (shed) in the garden.
The total plot size is 9m X 18m, whith the (detached) house at the front and the shed at the back right hand corner. The garage is on the front left hand side, and the consumer unit is on the outside wall. On the left hand side of the house is a grass verge and then a road. - All this info becomes relevant!!!
Currently the power to the shed was provided by a spur off the ring main. This provided power for 6 double sockets and a light!!!
Obviously I need to rectify this dangerous situation.
I want to install a new MCB in the consumer unit and have this protected by the RCD. There are currently 2 32A MCB (Upstairs and Downstairs) proteced by the 63A RCD. Do I need to upgrade this to a 100A RCD? Also, instead of putting in an MCB for the new circuit, can I put in an RCD? (So in effect, this circuit is protected by the main RCD and also by its own RCD).
Am I allowed to run the new cable along the outside of my garage to the garden? This means it will run "along" the grass verge.
Does this setup exceed the 100m2 area rule? i.e. do you calculate this area by imagining a square with the consumer unit in one corner and the shed in the other and then working out the area of the square?
Thanks in advance for your help.
Paul
Paul
