Extra deep circular boxes?
1 Sep 2008
Bedfordshire
I'm installing interlinked Kidde smoke alarms in my house, and the instructions it suggests using round dry-lining boxes in the ceiling to fix the alarm base into.
The ceilings in my house are lath-and-plaster which has been overboarded at some time with plasterboard, the total depth is 25-30mm (depending on the artex pattern in each room!). The deepest circular box I've seen allows 20mm plasterboard thickness. Does anyone know of dry-lining boxes that allow a deeper material?
Plan B is to trim away the lathes where the mounting lugs will go so the box clamps just the plasterboard and not the L&P, but as I have 10 alarms to fit I'd rather be able to perform one operation with a hole saw if possible.
Thanks. Unfortunately those ones are limited to 17mm material thickness.
Looks like I'll be trimming a lot of laths!!! :LOL:
Is there not enough meat on the ceiling to install the detectors surface mounted or are they a flush fitting type?
They could be surface mounted no problem as I could screw into a joist or install a noggin, but I thought I would stick to the manufacturer's instructions, even if it is a minor technicality that is unlikely to have any effect on the operation of the system! :D
Plan C:
Remove the lugs from the dry lining box
Use hole cutter to create a hole in the ceiling that the box just fits into - i.e. a tight fit
Glue the box in there with Gripfill or similar.
