I've installed a 24v ac pond pump in the garden. I didn't want to install a 240v ac pump as the supply work would be notifiable, but I think I am confusing myself on what is and isn't required.
I have had to extend the original cable to the pump, so have fitted a plastic JB and used a length of 0.75mm 2 core cable to run the extra distance in to the garage. The JB is only IP44 and the cover removable without the need for tools but as the system is selv, is this is ok.
View media item 81321
The supply is from a isolating transformer inside the garage, I was a bit surprised to see the output rated at 1A, could this cause harm even at low voltage?
View media item 81322
In the first pic I have protected the cable with metal covering and wondered if this should be earthed, but then reading up on selv, came across this "2. - there must be no connection whatever between the live parts of the SELV system and earth or the protective system of low voltage circuits. The danger here is that the earthed metalwork of another system may rise to a high potential under fault conditions and be imported into the SELV system."
so is what I've done ok?
(sorry the pics are sideways)[/img]
