I am building a new conservatory and I would like to put a radiator in it.
How easy is it to simply add a new radiator to my existing house system and have it in the conservatory? The closest is in my kitchen around 2-3 metres away.
Thanks, I only have two pipes on show going in and out of the rad , i presume this is the flow and return. if i added the rad in the conservatory would that be 'the end of the line' for the hot water?
What size rad do you think i need? Its a 2.5m*5m*2.5m hieght(approx) conservatory. How do I work it out?
This all sounds a bit complicated, is it? I like to do most stuff around the house and the conservatory I did myself, but is this best left to a professional?
