I am in the process of installing an extractor fan in the bathroom. The fan will be connected into the lighting circuit so that when the light is switched on the fan will come on as well. The fan has a timer that allows the fan to run for 15-20 minutes after the light is switched off.
I am using 3 core & earth cable to connect the fan to the ceiling rose. The problem I have is that the extractor fan has no connection for the earth wire. Am I correct in assuming that I do not use the earth wire in the 3 core cable at all?
Any advice would be very gratefully received.
Leggo
Leggo
