Extractor Fan Help
1 Feb 2008
Recently the window mounted extractor fan packed up and I've got to replace it. The old one is 150mm fan (no idea why as i've only got a very small bathroom) I'd like to use a 100mm fan (because they're smaller and cheaper :) ) The problem is there is a 184mm hole cut into the glass. Is there any way to fit a smaller fan without having to replace the whole window?!
Cheers
100mm fans are almost useless. Buy the bigger one to fit the window.
OK, I'll take your advice on getting the 150mm fan - any suggestions on a decent budget one that can can be window mounted?
Cheers
