Your hoover has no attachments?Bit difficult is you need a ladder or to remove fan to access.
Treat the wife.
Your vacuum has a 5m extension?Your hoover has no attachments?
Treat the wife.
Yes. It does. Then again, i wouldn't bother fitting insect mesh to the vent in that location.Your vacuum has a 5m extension?
That’s the point, any mesh fitted is not readily accessible to clean .Yes. It does. Then again, i wouldn't bother fitting insect mesh to the vent in that location.
So why would manufacturers make them like that?That’s the point, any mesh fitted is not readily accessible to clean .
Who makes them like what?So why would manufacturers make them like that?
Putting insect mesh on the inside of an exterior vent to be installed 5m above the ground - why would anyone do that?Who makes them like what?
Is that a rhetorical question?I’ve also increased the continuous running fan speed to it highest setting to such an extent the silent running continuous fan make continuous annoying hum, especially when two fans are running on either side of my living room.
Although the fridge running, is much louder but it’s not as noticeable or annoying ?
To keep insect out, isn’t that obvious.Putting insect mesh on the inside of an exterior vent to be installed 5m above the ground - why would anyone do that?
It was a question to receive a reply from the least intelligent person on the World Wide Web, thanksIs that a rhetorical question?
You're the one in the house, not us.
Keep looking.It was a question to receive a reply from the least intelligent person on the World Wide Web, thanks
I don’t like finding dead wood lice, earwigs or other things on my worktop below the fan in the kitchen or on top of the toilet cistern in the bathroom.
Found them and they keep responding not realising it’s themKeep looking.
