Hi
Probably been asked before somewhere
I have a house built 1972
Downstairs loo under the stairs had a large extractor fan set on an angled concrete block with an internal duct cast into party wall terminating on the roof.
I’ve removed the block and intend fitting a flush fan. The cable connection presently is via a flex outlet about 200mm from ceiling.
I was going to replace the outlet with a fan isolator but can’t find one with a flex outlet
Is there such an item?
I could fabricate a spacer with a surface mount plastic switch box.
I could chase out the wall and bury the cable before the decorators arrive.
But know I’m told I can’t fit a fan switch in the room. Is this correct?
There is a wall mounted light switch in the room already.
Or am I stuck with a flex outlet even though a fan switch is safer?
