Extractor Fan on pull switch dimmer
18 Jan 2007
Nottinghamshire
Chaps, I have checked all the connections and all is fine.
The bathroom extractor is on a pull dimmer switch, is there any reason why the fan would not work.
Help very much appreciated
Is it a dimmer pull switch with a proper switched output for a fan, or is the fan connected to the dimmed output?
Is it a timer or standard fan?
That's why it doesn't work. It's been cooked because it's not meant to be on a dimmer. Incidentally, where have you picked up the permanent live from?
Permanent live from the feed in at the light, cheers for that just realised my fau pas what an egit!!!
