Hi all
want to install an extractor fan which works of the from the lighting circuit but not the light switch
It would also have a timer fitted
want to meet all the regs so was first going to run power from bathroom light to Double pole isolator switch outside the bathroom.
I then wanted to run this to a pull switch before running it to the exractor fan which has a timer fitted
I'm guessing i'm going to have to activate the pull switch twice to start it again if left to shut off automatically on the timer. does anyone know a way around this?
also does this meet with the regs and could i just get away with a double pole pull switch as an isolator?
cheers
stu
cheers
stu
