Hi all
I am wiring a timed extractor fan in my bathroom and want the fan to switch with the light. I am aware that I need a perm live, switched l and neutral to a three pole isolator switch then to fan. I am unable to access junction box where existing lighting circuit is. I can access the l, s/l and neutral from the switch as ceiling had to come down anyway.
My question is 1, can I add a junction box to take the L S/l And neutral to the isolator.
2, the fan shouldn't be earthed but should the earth be conected in isolator and continued to fan then just put in a connector block with earth sleeve at fan. Or ended at isolator and again at the fan.
Sorry if it's an obvious question or doesn't make sense!
Thanks in advance 😊
Thanks in advance 😊
