I have just purchased a Vectaire RA10/4 Plus T extractor fan. The instructions are just about criminally negligent because the wiring diagram does not resemble the terminal block in the fan. Logic: I assume the fan needs 2 live sources in order for the timer overun to operate. I assume that there is only a requirement for one nuetral. I assume that the 3 input terminal marked SL N L stands for Switched live, neutral and permanent live. Am I going to blow myself up with this logic?Your kind and understanding replies would be much appreciated. I am not an electrician but have a fair bit of common sense. Do I need a building regs inspection for an upstairs toilet and sink. Basil53
