Most of what I've seen regarding levelling a concrete floor involves relatively small slopes. My garage slopes about 8" (20.3cm) over the 12" (3.65m) distance that I would like to level. Since I have pipes running under the existing concrete, I don't want to put up to another 8" of cement over it and then find I need to access that pipe down the road. So, should I try to build a 'boxed' subfloor over the concrete that is 8" on one end and goes to zero on the other? Is there a better way? Thanks!!
