I need to change a radiator valve, and want to use a set of 2 rubber bungs to avoid draining down (always get big airlock problems when refilling).
After fitting the bungs, water is still flowing slowly from the pipe connected to the rad. valve. When I removed the bung at the bottom of the F&E tank, I noticed that the hole (tank fitting) that the bung was pushed into isn't circular inside, it has a couple of lugs inside that prevent a good seal with the bung.
Does anyone have an ideas how to seal the bung. or can I buy a different one to fit?
