ok forgive my ignorance.........
I was up in the loft the other day and noticed when the boiler and pump sprang into life......so did the feed and expansion tank in the loft!
Is it supposed to do this?
What I mean is that will the boiler/pump running water was merrily coming out the expansion pipe at a reasonable rate.
The pump it just on the floor below the tank and the expansion pipe riser tee's off pipework quite close to the pump.
